Instead of creating a new material, you can modify the outermost material of the existing construction for the exterior walls. Change it's absorptance while retaining most the rest of the material properties (i.e., conductivity and specific heat).
Instead of creating a new material, you can modify the outermost material of the existing construction for the exterior walls. Change it's its absorptance while retaining most the rest of the material properties (i.e., conductivity and specific heat).
