Who knew?
It turns out that, when using RVI, the variable type is case-sensitive. That may also be true for the variable name. Once I made upper and lower cases identical in both the IDF and RVI files, it works perfectly.
I don't think I knew that any part of E+ was case-sensitive. I learned something new.
