1 | initial version |
I recently used the following configuration for a large hotel project with a similar design. The design called for a condenser loop providing HHW and CCW from boilers and fluid coolers to terminal WSHPs. The service hot water was heated by the condenser loop through a HX and storage tank system.
I added a HX to the demand side of the condenser loop (not shown) and then added the same HX to the supply side of the SHW loop. I also ended up simplifying the model by removing the WaterHeater:Mixed object. However, I did test the HX and WaterHeater:Mixed configuration and it also worked.
WSHP Loop
2 | No.2 Revision |
WSHP LoopLoop (HX is on the supply side off the screen)
SHW Loop
