I would approach this by modelling a verry large operable window with a transmittance of nearly 1, controlled by a schedule and set to be always open. Not sure if the schedule option is available in HB. What I do know for sure is that you can use a temperature setpoint to control the opening of windows in HB. So, if you set that to something verry low the window will always be opened.
The simpler alternative would be to use a window with a transmittance of ~1 and assume a verry high infiltration rate.
You cannot (or shouldn't be able to) set an external wall to air wall in honeybee. An airwall is used for interzone surfaces only. It will be translated to an opaque construction with a low thermal resistance and capacitance. Additionally it will create an interzone airexhcange object which exchanges air between the two adjecent zones. This is not possible if there is only one zone.
Changing the whole corridor into shading object is only fine if you are not interested in the temperature of the corridor itself. You then assume the temperature of corridor is the same as the outside air termperature.
