It sounds like the ExportScheduleCSV measure does what you want. Its description states "This script exports a CSV file containing values for each schedule in the model at a specified interval.".
Another option is to use the Add Output Variable measure and enter "Schedule Value" as the variable name. Leaving the key name as "*" will provide outputs for all schedules in the model.
