I was able to find the relation between CBECC-Com EER and the EnergyPlus Cooling COP. The EER in CBECC-Com gets adjusted, which is represented as EERAdj. This equation is present in section 5.7.5.2, eqn 15 from Nonresidential ACM reference Manual. A combination of eqns 6, 7 and 15 in Section 5.7.5 will give a relation that helps compute the Cooling COP, which is generated in the idf file.
