If you don't need to save anything from the original system you can use the heavy handed approach that is used on the AEDG HVAC measures. Everything is removed then the new systems is added. This is in the 'OsLiv_HVAC.rb' file in the resources directory. It is run before new systems are added.
def OsLib_HVAC.removeEquipment(model, runner)
airloops = model.getAirLoopHVACs
plantLoops = model.getPlantLoops
zones = model.getThermalZones
# remove all airloops
airloops.each do |air_loop|
air_loop.remove
end
# remove all zone equipment except zone exhaust fans
zones.each do |zone|
zone.equipment.each do |equip|
if equip.to_FanZoneExhaust.is_initialized
else
equip.remove
end
end
end
# remove plant loops
plantLoops.each do |plantLoop|
# get the demand components and see if water use connection, then save it
# notify user with info statement if supply side of plant loop had heat exchanger for refrigeration
usedForSHWorRefrigeration = false
plantLoop.demandComponents.each do |comp| #AP code to check your comments above
if comp.to_WaterUseConnections.is_initialized or comp.to_CoilWaterHeatingDesuperheater.is_initialized
usedForSHWorRefrigeration = true
end
end
if usedForSHWorRefrigeration == false
plantLoop.remove
else
runner.registerWarning("#{plantLoop.name} is used for SHW or refrigeration heat reclaim. Loop will not be deleted")
end
end #next plantLoop
end # end of def
![]() | 2 | No.2 Revision |
air_loop.remove
end
else
equip.remove
end
end
end
end
end
plantLoop.remove
else
end
end #next plantLoop
end # end of def
end # end of def
![]() | 3 | No.3 Revision |
If you don't need to save anything from the original system you can use the heavy handed approach that is used on the AEDG HVAC measures. Everything is removed then the new systems is added. This is in the 'OsLiv_HVAC.rb' 'OsLib_HVAC.rb' file in the resources directory. It is run before new systems are added.
air_loop.remove
end
else
equip.remove
end
end
end
end
end
plantLoop.remove
else
end
end #next plantLoop
end # end of def
