The answer appears to be no. With no responses I did a little test by trying to add a ZoneHVAC:UnitHeater to the AirflowNetwork_Attic_Duct.idf example file. The ZoneHVAC:UnitHeater is made of a fan and heating coil. The nodes are a zone air inlet and exhaust node. Energyplus started complaining once I added the exhaust node to the ZoneHVAC:EquipmentConnections object. Looks like the AFN in energyplus can only handle a single inlet and outlet per zone.
