This is my bad. I had tried with an array doing plant_loops_tokeep = [] and then 'plant_loops_tokeep += plant_loop` but it didn't work. This is a very basic Ruby mistake.
Here's code that works:
plant_loops = model.getPlantLoops
plant_loops_tokeep =[]
#Initial loop to store air loops
plant_loops.each do |plant_loop|
#Criteria...
if ....
# Correct way to assign to an array
plant_loops_tokeep << plant_loop
end #end if
end #end do
# Loop to retrieve air loop objects
plant_loops_tokeep.each do |plant_loop|
#Do stuff with the plant_loop, such as returning its name
runner.registerInfo("Plant loop name: #{plant_loop.name}")
end #end do
I'm still interested in knowing how one can return the object from its handle (especially without knowing the type of object it is).
#Criteria...
if ....
end #end if
end #end do
end #end do
I'm still interested in knowing how one can return the object from its handle handle (especially without knowing the type of object it is).
This is my bad. I had tried with an array doing plant_loops_tokeep = [] and then 'plant_loops_tokeep plant_loops_tokeep += plant_loop` plant_loop but it didn't work. This is a very basic Ruby mistake.
#Criteria...
if ....
end #end if
end #end do
end #end do
