I believe you will need to use Sketch Up Make 2017 to use the OS plugin. This doesn't include all of the functionality of Pro, but it is free. Older versions of Sketch Up can be found here:
https://help.sketchup.com/en/downloading-older-versions
Sketch Up - OpenStudio Compatibility:
https://github.com/NREL/OpenStudio/wiki/OpenStudio-Version-Compatibility-Matrix
