Since OA is controlled based on HVAC operation, it might be that the OA differs because the air loop operation is different (e.g., building loads are different).
Since OA is controlled based on HVAC operation, it might be that the OA differs because the air loop operation is different (e.g., building loads are different).different). You should also include information about the type of HVAC system to better understand possible reasons for the difference you see.
