I do not ever set these variables in the .bash_profile. I just symlink the openstudio CLI you want to use in /usr/local/bin (or equivalent).
For use in interactive ruby, I use pry with a .pryrc personally. (gem install pry).
You can just write ruby code to be executed before the session starts.
if Gem::Version.new(RUBY_VERSION) < Gem::Version.new("2.3")
# Do something
else
# Do something else
end
I have a prompt actually that allows me to select either openstudio installed or my local builds
print "Do you want OpenStudio (os) or os-debug (1) / os-release (2), or os-app-debug (3) / os-app-release (4): [os/1/2/3/4] "
input = gets.strip
# This typically loads a custom build installed on my computer
if input == '1'
p = File.join(ENV["HOME"], "Software/Others/OS-build/Products/ruby/openstudio")
elsif input == '2'
p = File.join(ENV["HOME"], "Software/Others/OS-build-release/Products/ruby/openstudio")
elseif ...
else
p = 'openstudio' # Installed openstudio
end
require p
puts "Loading '#{p}': #{OpenStudio::openStudioLongVersion}"
In your case, you can revamp that easily to have that prompt require either 2.8.1 or 2.9.1
print "Do you want OpenStudio 2.8.1 (1) or 2.9.1 (2): [1/2] "
input = gets.strip
if input == '1':
p = '/Users/home/Desktop/App/Run/OpenStudio/OpenStudio_2_8_1/Ruby/openstudio'
else
p = '/Users/home/Desktop/App/Run/OpenStudio/OpenStudio_2_9_1/Ruby/openstudio
end
require p
# Do something
else
# Do something else
end
input = gets.strip
if input == '1'
elsif input == '2'
elseif ...
else
end
require p
input = gets.strip
if input == '1':
else
end
require p
# Do something
else
# Do something else
end
input = gets.strip
if input == '1'
elsif input == '2'
elseif ...
else
end
require p
input = gets.strip
if input == '1':
else
end
require p
| 4 | No.4 Revision |
# Do something
else
# Do something else
end
input = gets.strip
if input == '1'
elsif input == '2'
elseif ...
else
end
require p
input = gets.strip
if input == '1':
else
'/Users/home/Desktop/App/Run/OpenStudio/OpenStudio_2_9_1/Ruby/openstudio'
end
require p
