Did someone find a solution to this?
I´ve tried @aaron comments, but the error Convergence error in SolveForWindowTemperatures persists.
I´m running the same model with two different weather files and only the second one (same location but Future weather 2050), throws this error.
UPDATE: For future reference, I´ve increased the minimum supply air temperature from the default 13ºC to 15ºC and the model runs without problems
