@Julian Nino, do you mean is there an OpenStudio measure Set_Skylight_To_Roof_Ratio similar to the Set_Window_To_WAll_Ratio_By_Facade measure? (https://bcl.nrel.gov/node/37880). There is not that I know of. At least not in the BCL. And the measure will not work on the roof as is. However, you could try to use it as a template to create a Set_Skylight_To_Roof_Ratio measure yourself. Shouldn't be very hard if you don't care about exact skylight geometry within a surface and could be fun!
