Hey @hodor, this is most likely because you are running an older version of EnergyPlus 8.2.0 which was released with a bug in the SQLite output. Several other people have reported this too.
If you have EnergyPlus 8.2.0 installed you should remove it and install EnergyPlus 8.2.0-Update-1 instead. You can tell if you have the right version of EnergyPlus by looking at eplusout.html, the version of EnergyPlus reported should be "Version 8.2.0-8397c2e30b"
