Ok i have re-engineered the example.osm of Air Wall Zone Mixing Building Component Library, by opening it in OS and export the IDF. Furthermore opening and checking IDF code with the needed code, for more purist energy modelers who rely on IDFs scripts.
Again, the same issue, if you export that model.osm to idf you will see the specified interzone surface is the same as above.
So the takeaway is that something is wrong with that solution, because it will generate an opaque surface. If it not can you explain only with IDF code what classes are missing, if no reply i'm sure my assumption is right and will hack those values which seem opposite to what a neutral interzone surface should be.
The interzone surface:
BuildingSurface:Detailed,
Surface 2, !- Name
Wall, !- Surface Type
Air Wall, !- Construction Name
Thermal Zone: Space 101, !- Zone Name
Surface, !- Outside Boundary Condition
Surface 21, !- Outside Boundary Condition Object
NoSun, !- Sun Exposure
NoWind, !- Wind Exposure
, !- View Factor to Ground
, !- Number of Vertices
24.384, 0, 3.048, !- X,Y,Z Vertex 1 {m}
24.384, 0, 0, !- X,Y,Z Vertex 2 {m}
0, 0, 0, !- X,Y,Z Vertex 3 {m}
0, 0, 3.048; !- X,Y,Z Vertex 4 {m}
the construction:
Construction,
Air Wall, !- Name
Air Wall Material; !- Layer 1
the material:
Material,
Air Wall Material, !- Name
MediumSmooth, !- Roughness
0.01, !- Thickness {m}
0.6, !- Conductivity {W/m-K}
800, !- Density {kg/m3}
1000, !- Specific Heat {J/kg-K}
0.95, !- Thermal Absorptance
0.7, !- Solar Absorptance
0.7; !- Visible Absorptance
So the takeaway is that something is wrong with that solution, because it will generate an opaque surface. If it not can you explain only with IDF code what classes are missing, if no reply i'm sure my assumption is right ok and will hack those values which seem opposite to what a neutral interzone surface should be.
Surface 2, !- Name
the construction:
Construction,
Air Wall, !- Name
the material:
Material,
