I'm not sure I understand what's your actual problem.
In IDF:
SET Param = %param%
Then you add it as a GenOpt param in command.txt
Vary {
Parameter{ // my EMS Global Param
Name = param;
Min = 0.1;
Ini = 3;
Max = 5.9;
Step = 0.2;
Similar to the example files that GenOpt ships with, no? eg: https://github.com/lbl-srg/GenOpt/blob/master/example/energyplus/8_5_0/GPSHookeJeeves/command.txt
