1 | initial version |
If you're using the OpenStudio application, you can go to the Simulation Settings tab, expand Simulation Control, and increase the "Maximum Number Of Warmup Days" above the default of 25.
2 | No.2 Revision |
If that doesn't help, there are also inputs below for "Temperature Convergence Tolerance Value" and "Loads Convergence Tolerance Values" that could be changed as a fallback.
3 | No.3 Revision |
