click to hide/show revision 1
initial version
To generalize, you are looking for functionality to edit extensible fields in EnergyPlus. Essentially you want functionality that treats an extensible field like a list, where you can append, insert, remove elements in the list
The package witheppy has this functionality. Take a look at extensiblefields2list and list2extensiblefields. If the documentation is not clear, open an issue in here
Note: See Readme for witheppy to see why this functionality is not yet in eppy
click to hide/show revision 2
No.2 Revision
JasonGlazer's answer is correct
This is a response to katsuya.obara's comment on ( Jan 14 '0 ) to JasonGlazer's answer
Thank you for your answer. So your answer is eppy does not have API to delete fields?
Response: eppy does not have that API. But you can get it from witheppy
click to hide/show revision 3
No.3 Revision
here is an illustration of how this can work:
# assme you have opened idf file
idf = IDF(idffilename)
# get the first "Daylighting:Controls"
daycs = idf.idfobjects["Daylighting:Controls"]
dayc1 = daycs[0]
print(dayc1)
    DAYLIGHTING:CONTROLS,
        ,                         !- Name
        ,                         !- Zone Name
        SplitFlux,                !- Daylighting Method
        ,                         !- Availability Schedule Name
        Continuous,               !- Lighting Control Type
        0.3,                      !- Minimum Input Power Fraction for Continuous or ContinuousOff Dimming Control
        0.2,                      !- Minimum Light Output Fraction for Continuous or ContinuousOff Dimming Control
        1,                        !- Number of Stepped Control Steps
        1,                        !- Probability Lighting will be Reset When Needed in Manual Stepped Control
        ,                         !- Glare Calculation Daylighting Reference Point Name
        0,                        !- Glare Calculation Azimuth Angle of View Direction Clockwise from Zone yAxis
        22,                       !- Maximum Allowable Discomfort Glare Index
        ,                         !- DElight Gridding Resolution
        Ref point 1,              !- Daylighting Reference Point 1 Name
        0.5,                      !- Fraction of Zone Controlled by Reference Point 1
        500,                      !- Illuminance Setpoint at Reference Point 1
        Ref point 2,              !- Daylighting Reference Point 2 Name
        0.5,                      !- Fraction of Zone Controlled by Reference Point 2
        500;                      !- Illuminance Setpoint at Reference Point 2
# extract the reference points as a list (You are extracting the extensible fields in a nested format)
extlist = extfields.extensiblefields2list(dayc1, nested=True)
print(extlist)
    [('Ref point 1', 0.5, 500.0), ('Ref point 2', 0.5, 500.0)]
# Remove the first Reference Point from the list
extlist.pop(0)
print(extlist)
    [('Ref point 2', 0.5, 500.0)]
# put the updated list back into the idfobject
extfields.list2extensiblefields(dayc1, extlist)
print(dayc1)
        ,                         !- Name
        ,                         !- Zone Name
        Ref point 2,              !- Daylighting Reference Point 1 Name
        500;                      !- Illuminance Setpoint at Reference Point 1
# note how the idfobject has changed
click to hide/show revision 4
No.4 Revision
# install witheppy by doing:
# pip intall witheppy
# witheppy will also install eppy
import witheppy
import eppy
import witheppy.eppyhelpers.extfields as extfields
dayc1 = daycs[0]
print(dayc1)
        ,                         !- Name
        ,                         !- Zone Name
print(extlist)
extlist.pop(0)
print(extlist)
print(dayc1)
        ,                         !- Name
        ,                         !- Zone Name
