Using weather file zip locally will not work (i.e. from your own machine). What I found worked was taking the desired zipped weather files, uploading them into Dropbox/Google Drive, then using the download link to those respective files into the Script Argument section for Worker Initialization Script.
However, I made sure to relabel the TMY2/TMY zipped file as if they were TMY3. And I changed the location-weather-filename and location-weather-year back to default. For some reason, it won't work otherwise. To sum it up, I was still able to use different weather files, but they're just labeled as if they were TMY3.
