Are either or both of these paths on your computer:
C:\Program Files (x86)\SketchUp\SketchUp 2015\ C:\Program Files\SketchUp\SketchUp 2015\
If 'C:\Program Files\SketchUp\SketchUp 2015\' that means you had installed 64 bit SketchUp at some point, check that the folder is empty and delete it. Then try installing 32 bit OpenStudio again.
