you'll need to use EMS / ExternalInterface to work via BCVTB. Those objects are wrapped in OS, so if you set them up correctly, your idf will be posed correctly when you try and run through BCVTB. Most of what you want will need to be done through a measure. This repo contains OS-Measures of the EMS examples EMS-Measures you can use as reference or an editing starting point.
