@katmojo Did you rename or move your OSM file away from the associated files. If you OSM is named MyModel.osm next to it should be a directory named MyModel. Inside that should be a file named floorplan.json. If this is the case, then rename the directory and the plan back to original name. You can also import the old floorplan.json using the geometry editor sub-tab.
