After you have made the prototype model you can change both the weather file and the design day files prior to running your analysis. You should only replace it for different locations in the same climate zone used to create the model, otherwise constructions and other characteristics may not be what would be expected.
The Site Tab of the OpenStudio Application is documented here.. Make sure to delete the design days from the original prototype location before importing design days from your target location.
