Good question, as of 1.7.0 as well. As a quick fix you can go in text mode, copy a quadratic curve (for water heater) and modify the values (including the name and handle)
![]() | 2 | No.2 Revision |
Good question, as As of 1.7.0 as well. this is still true.
As a quick fix you can go in text mode, copy a quadratic curve (for water heater) and modify the values (including values, including the name and handle)handle. Open the .osm file with a text editor and search for OS:Curve
For the handle, as it has been already discussed on this thread Creating handles for OSM objects, instead of changing a number or too it is best to generate a new version 4 UUID (for example here)
