Is it possible to use moisture measurements?
Otherwise, how would you add loads of humidity from people, plants, combustion, etc.? In my case, adding moisture loads as a latent source does not seem to be so correct as I can only add moisture from people in the best case. I am interested in calculating RH levels as a result of different ventilation strategies.
