Hi Chris, I am no longer with NREL so I don't know the most up to date plans. The plan a few months ago was to make the SketchUp plug-in normal SketchUp extension that you can install through the extension warehouse. There is an rbz file installer that you can download and install through SketchUp's normal extension dialog. On launch, the new extension should prompt you for the location of the OpenStudio SDK (e.g. where you installed OpenStudio 3.0). However, I have not tried this with the 3.0 prerelease because I no longer have access to a SketchUp 2019 license. If I am able to get a license to SketchUp 2019 I can try this out and make sure it works.
Updated Answer
I have uploaded a Windows only patch compatible with the OpenStudio Application 1.0.0-pre1 release to this dropbox link. To use this with SketchUp 2019 on Windows:
Let me know if that works for you!
Updated Answer
| 4 | No.4 Revision |
Updated AnswerAnswer - 11/30/19 - Possible Solution
