Amy,
Does the simple unit test Buildings.BoundaryConditions.WeatherData.BaseClasses.Examples.GetHeaderElement work for you with the weather file used in the example of the Buildings Library, and if so, does it work with your weather file? Are you using the JModelica docker image from https://github.com/lbl-srg/docker-ubuntu-jmodelica or another version? Loading files was fixed in JModelica about half a year ago, so if you use an old version, you may need to update.
The message you show looks like JModelica is just writing the function body to an output, but this is not an error message. Error messages should be in *_log.txt.
