You can use the LoadProfile:Plant
object to feed a scheduled load and flow rate to the plant. The schedule can be a year of measured or simulated data.
LoadProfile:Plant, \memo Used to simulate a scheduled plant loop demand profile. Load and flow rate are \memo specified using schedules. Positive values are heating loads, and negative values are \memo cooling loads. The actual load met is dependent on the performance of the supply \memo loop components.
![]() | 2 | No.2 Revision |
LoadProfile:Plant,
\memo loop components.components.
