I'm a little unclear about what you are asking here. It looks like you have included a table showing the cooling energy for a RHFS and a VRV system. How have you modelled the VRV system in eQUEST? Are you concerned that the energy savings for space cooling are too high? Is there something in particular that makes you think that they are too high? Given that the VRV building is said to have shading and given that the RHFS may have zone reheat (i.e. simultaneous heating and cooling) the results my be accurate. You might want to look at the output reports from eQUEST to try to get a better understanding of where the additional cooling energy in the RHFS system is coming from. For example, the LS-C report shows the peak cooling and heating load. You might want to check here to see if the shading drops the peak cooling load substantially. Also, the SS-E report shows the number of hours of coincident cooling-heating load for the building and the SS-C report shows the number of hours of coincident cooling-heating loads for an individual system. You can open the .SIM file in a text editor (it's in the same directory that the project files are saved in) or by selecting "Tools" -> "View Simulation Output" from the menubar.
From looking at the input files you sent me the following stand out:
If you are trying to figure out the cause of the difference in cooling savings I recommend that you start by looking at each change in the model in isolation.
Once the models are identical in all respects, apart from the system type (VRF vs. RHFS), check the cooling savings and compare them with your expectations. I strongly suspect they will be somewhat less than 50% after you have changed the lighting, matched the fins on the windows, and modelled the windows identically.
