Add the 'Zone Lights Electric Energy' and 'Zone Electric Equipment Electric Energy' Output:Variable objects to your model. If your HVAC system and domestic hot water systems are per-unit, you can make output variables for these objects and record them for each zone. Otherwise if they are served by a central system you'll need to allocate energy use by system load or some other means.
