This tutorial shows how to use the Sketchup Plugin to view daylighting. There is also this helpful video that explains how you can view output results in the sketchup plugin https://www.youtube.com/watch?v=TI_uygHShL0.
You should also check out the "View data" measure directly in OpenStudio - it allows you to view any output variable. I would assume that could be used for daylighting but I've never used it for this purpose before. You can follow this tutorial on how to add and use the view data measure: https://www.youtube.com/watch?v=PlrWE3ugcdE
Hope this helps.
Hope this helps.
This tutorialtutorial shows how to use the Sketchup Plugin to view daylighting. There is also this helpful video that explains how you can view output results in the sketchup plugin https://www.youtube.com/watch?v=TI_uygHShL0.
Hope this helps.
