1 | initial version |
Have you tried running your model before applying the baseline measure?
In the model you linked, 500 out of 666 spaces do not have a thermal zone. EnergyPlus is based on thermal zones and will fail if you have spaces in your model without them.
Get your proposed model running first before trying to implement the baseline building measure.
