1 | initial version |
There is not a prototypical building for growing facilities. You could emulate one by using the Warehouse prototype model and then increasing lighting levels to match a growing environment. You may also need to lower the default zone occupant activity level.
2 | No.2 Revision |
There is not a prototypical building for growing facilities. You could emulate one by using the Warehouse prototype model and then increasing lighting levels to match a growing environment. You may also need to lower the default zone occupant activity level. level depending on the agricultural product.
