Sketchup is single-threaded, like most (if not all) 3d modelers out there. I assume you have 4 CPU which have hyperthreading, so 8 threads... Hence why you're seeing 12%: 100%/8 ~= 12% .
Adding new thermal zones for spaces with no thermal zones would probably be a lot faster using the bindings directly.
Adding new thermal zones for spaces with no thermal zones would probably be a lot faster using the ruby bindings directly.
# get all spaces
spaces = model.getSpaces
# loop through spaces
spaces.each do |space|
next if !space.thermalZone.empty?
z = OpenStudio::Model::ThermalZone.new(model)
# Rename like space + " Zn"
z.setName("#{space.name.to_s} Zn")
space.setThermalZone(z)
end
