I am assuming you already know how to use EnergyPlus (setting thermal zones, constructions, ZoneHVAC):
The ZoneHVAC:LowTemperatureRadiant objects are not controlled by your zone thermostat, instead, they have an separate temperature schedule that will look at the metric that you select in the Temperature Control Type parameter.
