Is there any way to display BOTH Energyplus results AND Openstudio results in IP units? If we run the "Energyplus output to IP" measure, the OS results will fail, because this measure is expecting SI units, right? If we omit this Energyplus measure and run only the OpenStudio Results measure, then we DO get IP Openstudio results, but we do not get IP Energyplus results, just the SI version. How can we get both in IP? Thanks. See related, unresolved thread from last year: https://unmethours.com/question/28989/set-output-table-to-ip-units/
