Depending on the amount of output variables you have, DView could take 10min+ to load and render your data. Try opening DView standalone (outside of the app), then navigate to the results .sql file and load it from there. If the time it takes to open is still too irksome, you will need to remove some output variable requests from your model. I'd suggest specifying specific surface names when you are requesting surface temperatures. Exporting all surface temperatures from a model could be a lot of data.
