As far as I'm aware, every type of EnergyPlus schedule can handle sub-hourly data. If you're wanting to import a schedule from elsewhere, you might consider using the Schedule:File object, which has a Minutes per Item field.
As far as I'm aware, every type of EnergyPlus schedule can handle sub-hourly data. If you're wanting to import a schedule from elsewhere, you might consider using the Schedule:File object, which has a Minutes per Item field.field. It allows you to create your schedule in a CSV file, for example.
