All EnergyPlus Output:Variable can be exposed as Outputs of an EnergyPlus FMU. So if this variable exists as an EnergyPlus Output:Variable and you can report it when performing a regular EnergyPlus simulation (with no FMU in-the-loop), then there is no reason why you shouldn't be able to extract the value from the FMU.
