Here's how you would load DDY file, and try to limit yourself to the two most common design days:
if !OpenStudio::exists(ddy_path)
raise "Path doesn't exist: #{ddy_path}"
end
ddy_idf = OpenStudio::IdfFile::load(ddy_path, "EnergyPlus".to_IddFileType).get
ddy_workspace = OpenStudio::Workspace.new(ddy_idf)
reverse_translator = OpenStudio::EnergyPlus::ReverseTranslator.new()
ddy_model = reverse_translator.translateWorkspace(ddy_workspace)
# Try to limit to the two main design days
ddy_objects = ddy_model.getDesignDays().select { |d| d.name.get.include?('.4% Condns DB') || d.name.get.include?('99.6% Condns DB') }
# Otherwise, get all .4% and 99.6%
if ddy_objects.size < 2
ddy_objects = ddy_model.getDesignDays().select { |d| d.name.get.include?('.4%') || d.name.get.include?('99.6%') }
end
#add the objects in the ddy file to the model
model.addObjects(ddy_objects)
This is loosely adapted from what we do in OpenStudio-resources, where we look at the workflow.osw to find the EPW name and load the matching DDY file next to it. See code here
