A chiller can be placed on the demand side of an Plant Loop without any problems, and you're free to put whatever you want on the supply side on that plant loop, including a chiller, so there's no issue modeling your setup.
I've just setup a dummy test case in openstudio where I modeled 3 PlantLoops:
It simulated without any problems as I expected.
Here's a Gist with my model, built with OpenStudio 2.7.1 (was the version I had installed on the machine I used, don't read too much into it).
