Please try to change the vertices of three surfaces to what's shown below, the errors should be fixed.
FenestrationSurface:Detailed, Entrance Door, !- Name Window, !- Surface Type Window_U_0.41_SHGC_0.38, !- Construction Name g EWall C, !- Building Surface Name , !- Outside Boundary Condition Object autocalculate, !- View Factor to Ground , !- Frame and Divider Name 1, !- Multiplier 4, !- Number of Vertices 46.327341000000,0.050800000000,0.025400000000, !- X,Y,Z ==> Vertex 1 {m} 46.327341000000,0.050800000000,2.133500000000, !- X,Y,Z ==> Vertex 2 {m} 46.327341000000,1.625500000000,2.133500000000, !- X,Y,Z ==> Vertex 3 {m} 46.327341000000,1.625500000000,0.025400000000; !- X,Y,Z ==> Vertex 4 {m}
FenestrationSurface:Detailed, MWindow14, !- Name Window, !- Surface Type Window_U_0.41_SHGC_0.38, !- Construction Name m EWall C, !- Building Surface Name , !- Outside Boundary Condition Object autocalculate, !- View Factor to Ground , !- Frame and Divider Name 1, !- Multiplier 4, !- Number of Vertices 46.327341000000,0.381000000000,0.954000000000, !- X,Y,Z ==> Vertex 1 {m} 46.327341000000,0.381000000000,2.173100000000, !- X,Y,Z ==> Vertex 2 {m} 46.327341000000,1.295300000000,2.173100000000, !- X,Y,Z ==> Vertex 3 {m} 46.327341000000,1.295300000000,0.954000000000; !- X,Y,Z ==> Vertex 4 {m}
FenestrationSurface:Detailed, TWindow14, !- Name Window, !- Surface Type Window_U_0.41_SHGC_0.38, !- Construction Name t EWall C, !- Building Surface Name , !- Outside Boundary Condition Object autocalculate, !- View Factor to Ground , !- Frame and Divider Name 1, !- Multiplier 4, !- Number of Vertices 46.327341000000,0.381000000000,0.954000000000, !- X,Y,Z ==> Vertex 1 {m} 46.327341000000,0.381000000000,2.173100000000, !- X,Y,Z ==> Vertex 2 {m} 46.327341000000,1.295300000000,2.173100000000, !- X,Y,Z ==> Vertex 3 {m} 46.327341000000,1.295300000000,0.954000000000; !- X,Y,Z ==> Vertex 4 {m}
1, !- Multiplier
