Hi Jdubster,
This happens because your manually inputted effective leakage area does not update the same as your manually entered air leakage value. It's a HOT2000 bug.
To fix it, make sure the effective leakage area is selected to "calculated" and not "user defined". This automatically changes sometimes. =Next, manually click on your effective leakage area and make sure it updates when you change your air leakage value. Send me a message if you can't figure it out and still get this error. I don't have H2K on this pc now but can send a screenshot of the fix if that would be helpful.
