The reporting availability is shown in the rdd file after you run a simulation. The zone loads can be seen (if you have a thermostat and/or humidistat) by including any of these in your input file. The reporting frequency (in this case hourly) can be changed to any of detailed, timestep, hourly, daily, monthly, runperiod or annual. See Input Output Reference document on Output:Variable for more details.
Output:Variable,*,Zone Predicted Sensible Load to Setpoint Heat Transfer Rate,hourly;
Output:Variable,*,Zone Predicted Sensible Load to Heating Setpoint Heat Transfer Rate,hourly;
Output:Variable,*,Zone Predicted Sensible Load to Cooling Setpoint Heat Transfer Rate,hourly;
Output:Variable,*,Zone Predicted Moisture Load Moisture Transfer Rate,hourly;
Output:Variable,*,Zone Predicted Moisture Load to Humidifying Setpoint Moisture Transfer Rate,hourly;
Output:Variable,*,Zone Predicted Moisture Load to Dehumidifying Setpoint Moisture Transfer Rate,hourly;
