Thanks a lot for the answer. I have now tried to write my own measure. During this struggle I was inspired by an existing EnergyPlus measure from the BCL-web (AEDG K12 - SlabAndBasement) which includes "a call" to a short idf-file to include new objects. So I wrote a measure with the following code in the measure run section:
dummyIdfPath = OpenStudio::Path.new("#{File.dirname(__FILE__)}/resources/dummy.idf")
dummyIdf = OpenStudio::Workspace::load(dummyIdfPath).get
workspace.addObjects(dummyIdf.objects)
Then I can use the e+ IDFEditor to create dummy-files containing whatever objects not covered by OpenStudio and put them in a folder named resources in the measure folder. Preliminary tests indicates that it works. The test objects anyway turns up in the ...run\4-EnergyPlusPreProcess-0-folder.
Amendment: Later I have concluded that the method above is a useful method to add things to the idf before e+ receives it. However does OpenStudio run the ExpandObjects before running the Measure and it is during the ExpandObjects run that the Basement related objects must be present in the idf to have desired impact. My final, slightly simplified, solution to my problem is as follows:
Now I can continue work in the OpenStudio model and run simulations without bothering to much about the basement heat transfer as long as I do not modify parameters related to it. I realise that this could have been done more elegant, but this is good enough for my purposes anyway.
