Which DOE-2.2 library file are you referring to? The curves you're showing on the screenshots are in the eq_lib.dat file. This file is not typically empty. Figure 37 in the DOE-2 help (look for the help onSUPPLY-KW/FLOW) shows you part-load operation for different methods of air flow control, if this doesn't help, I would suggest plotting the curves to see if their part-load operation describes what you intend to model.
