RunEplus.bat is deprecated. Use the Command Line Interface (CLI) energyplus indeed.
You just need to read the documentation, the key information can also be gotten directly in your terminal via energyplus --help (see example at end of post).
Anyways, in your case, what you want is to the pass the -x (or equivalent --expandobjects) flag to ensure that expandObjects is run. You will probably be interested in -r too if you want to get CSV files out.
Example to run with expandobjects and readvareso, use weather.epw to run in.epw and output results in a out/ folder:
energyplus -w weather.epw -d out/ -r -x in.epw
$ energyplus --help
EnergyPlus, Version 9.2.0-4f4f5d8ca1
Usage: energyplus [options] [input-file]
Options:
-a, --annual Force annual simulation
-c, --convert Output IDF->epJSON or epJSON->IDF, dependent on
input file type
-D, --design-day Force design-day-only simulation
-d, --output-directory ARG Output directory path (default: current
directory)
-h, --help Display help information
-i, --idd ARG Input data dictionary path (default: Energy+.idd
in executable directory)
-m, --epmacro Run EPMacro prior to simulation
-p, --output-prefix ARG Prefix for output file names (default: eplus)
-r, --readvars Run ReadVarsESO after simulation
-s, --output-suffix ARG Suffix style for output file names (default: L)
L: Legacy (e.g., eplustbl.csv)
C: Capital (e.g., eplusTable.csv)
D: Dash (e.g., eplus-table.csv)
-v, --version Display version information
-w, --weather ARG Weather file path (default: in.epw in current
directory)
-x, --expandobjects Run ExpandObjects prior to simulation
Example: energyplus -w weather.epw -r input.idf
energyplus -w weather.epw -d out/ -r -x in.epwin.epw
Example of embedded CLI help:
$ energyplus --help
Options:
input file type
directory)
directory)
in.idf
$ energyplus --help
Options:
input file type
directory)
directory)
