I think you can use Unit ventilation system(zero fan energy and modify "Heat Source" to "Not Installed" ) to serve the corridor.Take outdoor air from DOAS by OA-FROM-SYSTEM keyword.
I think you can use Unit ventilation system(zero fan energy and modify "Heat Source" to "Not Installed" ) to serve the corridor.Take corridor.And take outdoor air from DOAS by OA-FROM-SYSTEM keyword.
