I'm not 100% positive, but the PTAC SYSTEM:TYPE in not available anymore in DOE-2.3. This system was used by the Wizard to create PTHPs in earlier version of eQUEST. That being said, you can model a PTHP system type using a PSZ or PVVT system you just need to adjut your inputs int the detailed mode.
